Page 1 of 28 1234511 ... LastLast
Results 1 to 10 of 275
  1. Collapse Details
    GH1 and GF1 valid serial range
    #1
    Default
    Edit:- Many Questions are being posted in this thread by people not even reading this first thread. So, here is a summary of Qs.
    1. I have a serial no. XXXX.... Will the Hack work ?
    a) If you have a serial such as a XX9XX.... i.e. 3rd letter is 9. It will work. Otherwise, the following combinations will work. XX0A.... , XX0B.... , XX0C... , XX0D.... , XX0E ....
    XX0F MAY work - but its not worth buying in this range.
    2. I have to buy blind i.e. I cannot see the serial. How can I increase my chances of a hackable body ?
    a. Buy the Gold body, and if not available, buy the Red Body. These are the colors that most people DO NOT buy, and from the posts of people in this thread, they seem to work.
    3. I got a firmware in range - but I could not flash. Can you help me ?
    a. You are making a mistake. Go through the steps again. Have you ticked the appropriate settings in ptool ? Have you actually copied the right firmware on your SDHC card ? Have you pressed the Play button to enable firmware update ?
    In this thread, I will be collecting information about the serials that work and dont work. Hopefully we can collect information and decide the serial no cutoff.
    RESULTS :-
    Look at the serial on the camera.
    Further, it seems that the combo of the 3rd and 4th characters give the year and month.
    0F indicates June 2010
    0G indicates July 2010
    9J indicates October 2009
    In some cases, S seems to be used for September, so
    0S indicates September 2010
    So 0G, 0H, ... will not work
    0F may work
    anything lower than 0F will work and all 9X will work.
    First check the service for the exact firmware version using instructions from this post.
    http://www.dvxuser.com/V6/showpost.p...88&postcount=1
    Temporary service mode:
    1) Non-empty SD card must be installed
    2) Check that single shot mode is selected.
    3) Before trning on camera press:
    a) DISPLAY+FILM MODE for G1 and GH1
    b) DISPLAY+AE LOCK for GF1, G2, G10
    4) Turn on power.
    You must see ROM BACKUP option in settings menu.
    Error code table in this mode:
    1) Press left arrow + MENU/SET and hold them, plus press
    a) FILM MODE for G1 and GH1
    b) DISPLAY for GF1
    c) AF/AE LOCK for G2 and G10
    If you repeat error code table method one more time for'll be in CAMERA INFO screen.
    Pressing Display will show you CAMERA INFO 2 screen.
    If you see version 1.34 for GH1 or 1.24 for GF1 the hack will not work.
    The third number in the serial seems to be the year of manufacture, so 9 will work and 0 may or may not work.
    For GH1 these seem to work
    WE9XXXXXXX
    These may or may not work.
    WE0XXXXXXX
    FS0XXXXXXX
    From this post
    http://www.dvxuser.com/V6/showpost.p...5&postcount=60
    the new 1.34 firmware started some where in between my WE0FD0012XX and crunchys slightly earlier WE0FD0010XX.
    From this post
    http://www.dvxuser.com/V6/showpost.p...5&postcount=84
    WE0FD001041 does not work
    0F may work
    As an aside, from Vitaliy's post.
    http://www.dvxuser.com/V6/showpost.p...6&postcount=45
    First two letters must represent factory and production line.
    As Japan bodies seems to have serials started with F and Chinese ones with W.
    Please post ONLY if you have a serial > than what I have posted. Let us know if the hack works or not.
    mishra.tv Productions
    Movement & Sound
    Cameras GH13 - Made in Japan, 7D, HV20, HV30, SD780IS, SX200IS
  2. Collapse Details
    #2
    Default
    I recently purchased 2 x GH1, REd and Gold version from Ebay supplier in Taiwan..
    Both took the hack no problem..
    Serial numbers:
    FS0AD001145, 1147
    cheers
  3. Collapse Details
    #3
    Default
    GF1 FV0GC1020XX DOESN'T WORK
    And in the service mode :
    VER 1.24:0000
    NO.: f9110070901XX (looks like it was manufactored in 2010.07.09, bought last week)
  4. Collapse Details
    #4
    Default
    Stick it!
    RED ONE @home
    #111
    Emanuel & Co's RED ONE
    #647
    RED ZOOM LENSES
    #156
    #157
    RED 300mm LENS
    #82
    Who am I?
    * LINK *
    ** IMDb **
  5. Collapse Details
    #5
    Default
    GF1 FV0FC1015XX DOESN'T WORK
    Bought on July 24th in Taiwan, Japaness language interface only
    VER 1.24:0000
    NO.: F9110061700XX (looks like it was manufactored in 2010.06.17)
  6. Collapse Details
    #6
    Default
    GF1 FV0FC001046 WORKS!
    Bought exactly a month ago in Japan, was able to change the language and hack the camera
  7. Collapse Details
    #7
    Senior Member Chris Light's Avatar
    Join Date
    May 2008
    Location
    Fallbrook, CA
    Posts
    2,076
    Default
    GH1 WE9JB001184 WORKS
    Purchased Nov 09 from Amazon
    "Easier than it sounds, harder than it looks."
    Chris Light
    www.vimeo.com/chrislight
  8. Collapse Details
    #8
    Senior Member JoeJITSU's Avatar
    Join Date
    Jan 2010
    Location
    Las Vegas
    Posts
    1,211
    Default
    We9kb00236 works
  9. Collapse Details
    #9
    Bronze Member
    Join Date
    Mar 2010
    Posts
    1,559
    Default
    you should post not just the serial # but also the DATE when you purchased so that we can correlate the serials to dates and see if there is a correlation
  10. Collapse Details
    #10
    Bronze Member
    Join Date
    Mar 2010
    Posts
    1,559
    Default
    mine is WE9SB001620 purchased october 2009 from B&H
    hack works
Posting Permissions
  • You may not post replies
  • You may not edit your posts
